Edge Wall Mount – 15” Wall Mounted fan with 3 x ABS Matte White blades, 90 degree Oscillation
Fanzart - Luxury Designer Fans
The Edge white can blend in with your interiors or can pop out against a highlighted wall. The sheer power of the fan will keep your room breezy and well ventilated. This 15inch remote-controlled DC motor fan can oscillate 90 degrees thus covering a wider area and displaces 9221 CFM of air and consumes around 20 – 35 watts of power only making it energy efficient. In addition, the fan can also be set to the desired vertical tilt angle to direct airflow towards the area of your choice. Equipped with our novel Summer Winter feature, the EDGE white makes the perfect choice for your modern home or office.
